I cant seem to break a pipe in revit 2012.
The split with gap doesnt work. The split adds a socket or a flange (depending on routing preferences), but mends itself when the fitting is deleted.
To wrap a beam or a duct, I am cutting a tee into the pipe to run around the obstruction, then deleting between the tees and converting the tees to elbows!
There must be a better way!
TIA
Pete
Solved by abulla. Go to Solution.
Thanks Abdulla
You are saying thatr the best solution to adding a wrap is to split the pipe either side of the obstruction, then delete the pipe and the added sockets/couplings/flanges then re-route the pipe?
If this is the case, I hope they improve it in new versions
Cheers
Pete
