I have had problems with Revit 2012 frequently crashing when manipulating sections
With the section view open, I can move the scope box with no problems, however, when I try to move the section itself, Revit often crashes. I found that closing the view, moving the section line then re-opening the view works without problem.
Has anybody else had this problem?
Solved by arief.rahman. Go to Solution.
I haven't had this problem, but try toggling "Use Hardware Acceleration" under Options > Graphics. Also, verify that your graphics card is on "the list"; >this link< might be helpful.
Please check that you have already updated all service pack and hotfixs for Revit 2012.
The Update and hotfix for revit you can find on this link below :
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
