Hi
when drawing copper pipe in Revit MEP 2012 why do the elbows and reducers show much smaller tha the pipe being drawn when detail level is set to fine and visual style set to realistic.
e.g. I draw a 35mm Cu pipe and although the elbow size in the properties dialogue shows as the correct size, it displays as tiny in plan/3D views etc.
Solved by abulla. Go to Solution.
Sounds like a lookup table problem. Make sure that within your revit.ini file:
C:\Users\username\AppData\Roaming\Autodesk\Revit\Autodesk Revit MEP 2012\revit.ini
LookupTableLocation should be set to wherever the lookup tables are located.
