Revit MEP Forum
middle Duct segment error
2 REPLIES 2
GHASEM_ARIYANI
293 Views, 2 Replies
Hi
I've drawn two-Ducts level difference،Together they are parallel but not a direction.
When I draw a middle Duct segment error and does not allow drawing.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
luna.ye
in reply to: GHASEM_ARIYANI
Hi gh_ar,
This issue may be due to lack of duct fitting or the duct fittings don’t match the spacing. Please try to increase spacing or change another duct fitting. Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
try changing the duct from (radius Elbow / Tees) to mitered !!, after that change the elbows to radius manually
it is better to habe both ducts the same size
reagrds
Forma Design Contest
