Is it possible to put an If/Then statement in a duct label?
I have vertical ducts that sometimes report their size as 48x12 and sometimes 12x48. I would like to make one label that covers both situations, and uses an If/Then statement to place the larger value first and the smaller value last.
But I can seem to get at the duct properties from within the Family Types dialog of the Label family.
Any thoughts here?
Solved by CoreyDaun. Go to Solution.
Unfortunately, no. Labels cannot be dependent on data; all they are capable of doing is reporting it. And since Duct are System Families, you can't create a Shared Parameter with a formula, either. The best you can do is to create an alternate Tag/Label that manually reports "Width" and "Height" individually, but reversed. Of course, the Tag Type would have to be controlled manually.
Can a shared parameter be created to repeat/ report the value of a system family, Then the shared parameter used in formula's,schedules and tags?
