You can right click the wire and select "override graphics in view" the line pattern.
You can do it by category, filter or element. after that you just select the color, pattern and others things. I just foud it out by looking for how to make the pattern dashed for underground lines.
Good luck!
You can create a filter to change a line type to dashed for any pipe below grade by using the belo.
Hi @Anonymous,
I hope you doing well.
Are you get your expectable solution? Please notify.
Awaiting.
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
