Revit MEP Forum
How to change the size of a sidewall grille in Revit
6 REPLIES 6
1454 Views, 6 Replies
I am trying to export a sidewall grille from Revit 2013 to AutoCAD MEP to use in a drawing and they only have certain sizes in the templates. Can I change the size of the part before I export it? ie they have a 10" x 6" and I need a 10" x 8". I am really new to this and would appreciate any help.
6 REPLIES 6
danielkazado
 After you insert the grille to Revit, select the grille and click Edit Type button on Properties. There you can dublicate the grille and change the size.
 Hope this may help you.
Daniel
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
It's not working or I am doing something wrong. Can you give a little more detail on the process?
Sorry, but I have been trying and cannot get it to work.
Thanks again!
danielkazado
 Find below the link of video in youtube I made. Check if it works for you.
http://www.youtube.com/watch?v=0ZU8HaAJuNU
Daniel
NOTE:
Please Click "Accept as Solution" below if your question is answered.
Kudos are welcomed.
Daniel Kazado
Daniel,
The video says it is private? I logged into YouTube and it still wont work?
danielkazado
I made it public now, can you please check again.
Daniel Kazado
Daniel,
Thanks for the help! Much appreciated!
Forma Design Contest
