While you are in the DWG Export dialog selecting views/sheets, click on the "" button beside the pull-down under "Select Export Setup".
You'll have to create an Export Setup here to get a custom configuration, in which you can assign layer names and colors as desired. Beware, there are a number of limitations, such as element Phasing for example.
Corey D. ──────────────────────────────────────────────────────────────────────⁞|⁞ Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
