I am a beginner with Revit MEP and I tried some HC calculation so please correct me if I'm wrong, but can anyone explain::
- why Revit MEP 2012 does not consider floor transmition in the heating and cooling calculation
- why it is so difficult to change thermal and optical properties of construction (via editing Construction.xml)
- why it is not possible to give thermal and optical properties to walls, floor, windows, etc., that I place to model and calculate with these values
These things make heating and cooling calculation almost unusable.
Thanks.
But it is a pity. Is it really so difficult to test program on real project in cooperation with real HVAC designers? I don't believe it happened.
OK, now when Autodesk knows about the problem, I"m looking forward to patch that fixes this bug and I believe i doesn't take them more than a month of work.
I am not actually sure with my answer thus I am not an expert in this field But I can always ask my uncle because he is working in air-conditioning indianapolis and he is an expert to that field. No need to worry I'll ask him when he gets home.
Hey,
As far as i know, this issue is in Autodesk's to do list. Until then, did you guys find any workaround to fix this bug?
