Hi is there any way to give dimension to the bottom of the duct in cross section.
Present we are draw a line at the bottom of the duct and dimension given to the line.
Thanks in advance.
Solved by CoreyDaun. Go to Solution.
do you mean you want to make the duct on certain height from the floor that you request on the section ?
if so, you make the section, make the Dim. for it
then click on the duct, after than you will see the Dim. value became smaller size, click on it, specify the lenght
hope i didn't get you wrong
regards
Hi chunkey
thanks for the reply.
I attach a revit model in 2013.I need bottom of duct in section without drawing a line.
Hi
Sorry, if I am wrong. My doubt is not about prefix or suffix.
What I mean is how can I draw dimension to the bottom of the duct.
Default dimension can take only to the center of the duct.
I am unable to take dimension to the bottom of the duct.
Thanks in advance
Hmm I'm not sure what the problem is then. Are you using an Aligned Dimension or a Linear Dimension? I was able to tag the top and bottom with an aligned dimension, I had to press tab to select the center of the ductwork.
In the initial Section View in the sample project you attached, the Rise/Drop symbol is preventing you from selecting the top or bottom of the Duct. Open Visibility/Graphics Overrides and temporarily turn off the "Drop" and "Rise" Subcategories under Ducts.
Hi cadstrophe
thanks for the solutions. We are wasting our time with drawing a line for every bottom of the duct from long time.
thanks for all.
