Using Revit MEP 2011 and still no fix. I have room names that are on top of my duct work/equip and text. The only thing I see so far is to make sure you get your room names on the plan before doing your work. BUT with the Arch. always changing the plans you have to update room names. There is a fix for linked backgrounds but not if you add room names on your plan.
ok they have this on a search from within Revit.
You can sort the draw order of detail components in a view. Draw order options are available when you select detail components in the view.
This functionality is also available in the Family Editor (for detail components in the Detail and Profile families), and for raster images.
The following tools become available on the Modify <element> tabArrange panel.
I cannot find a arrange panel?
That seems to be for "Detail Items" ONLY. I have the same issues with Space Tags and other junk- the "Plot" looks good, but PDFs are lousy.
v 2012 and still no progress. This seems really fundamental. I'm drawing a plumbing plan and the pipes don't show clearly. 4 years seems like a long enough lead time to get something this important fixed.
Anyone have a suggested work around?
