Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Docking MEP 2015
4 REPLIES 4
521 Views, 4 Replies
Docking MEP 2015
Hi There,
I seem to have lost the Naviation wheel.  It used to be automatic under the Cube on the right and now it's gone.  F8 brings it back on temporarily but I would like it docked there all of the time like it used to be.
I also stuffed up my Project Browser and Properties.  They used to be docked on the left, one above the other which was nice and I think the default.  Now each is the full length of the left with tabs at the bottom.  I would like to return back to one above the other.
Thanks in advance.
Paul
4 REPLIES 4
L.Maas
I am not sure what you see exactly. If the whole navigation bar has disappeared you can get it back via "View", "User Interface":
If you miss icons on the nav bar or docking position then use the small downward arrow on the navigation bar.
Louis
Please mention Revit version, especially when uploading Revit files.
in reply to: L.Maas
Thanks for that and that solved the nagivation issue.
Thanks in advance.
Cheers
Paul
L.Maas
First dock your project browser (or properties window) to the left side of the screen.
If you drag (select and keep left mouse button down) the other window then move it over the docked window. Depending how and where you move around you will see gray borders appear. When the gray border apeaars in the right position relaese your mouse button and it wil. dock in that place.
In the screenshot I am dragging my properties window over the already docked project browser. After releasing they will be stacked on top of each other.
Louis
in reply to: L.Maas
Good job thanks!
Forma Design Contest
