I am in Revit MEP 2013
I am on the second floor of a multi story building.. There is a shaft opening were I can see the pipes on the first floor. I would like these pipes to display single line but even when I am in Detail Level: Medium they show up Double line.. How can I change this.
Solved by jkarben. Go to Solution.
Hello pverduzco,
I've not been successful in reproducing this scenario. Would you be able to mock this up in a New Project and post that file here? In order to get the file small enough to post here, you'll have to use the Purge Unused a few times and then manually remove all of the unused Pipe and Duct Fitting Families from the Project Browser.
Sorry for the delay of response.
Thanks for your response.
This is a 6 flr building so It might take me a while but I will try and do the process you mentioned and upload it.
thanks
Check the view's Underlay parameter. Looks like it may be set to First Floor. Change it to <none> and then go from there.
I am guessing you are in a view that was duplicated. When you duplicate a view, Revit will automatically add an underlay. Just clear the check, and it should be fine.
