I am trying to model a continuous lighting fixture with no preset length. My goal is create an instance parameter to where I can put the length while on the project. I tried to make the "Length" as Instance Parameter but have a problem with the "Emit from Line Length" parameter (can't modify).
Any advise will be much appreciated.
Solved by Alfredo_Medina. Go to Solution.
Select the light source object and change the default association of the "Emit from line length" property to your "length" instance parameter, instead of the default type parameter.
