Show only
Search instead for
For some reason everytime I change the number of poles from 1 to 2 or three, I cannot connect the element ( junction box) with the elect. panel.) Does someone know any reason for that to happen???
Thanks a lot
The only reason I'm aware that an element will not connect to a panel is if it's missing a connector or the voltage of the element does not match the voltage of the panel (taking for granted the panel has been given a distribution system).
Thank you for your answer! You are right. One minute after placing the question there, I found out the solution. I have the same problem with the air conditioned fancoils... It must be the same thing. At least now I know!!!:)
