Just completed my 1st Revit (v.2011) project
- 6 floor, 250 unit apartment complex with retail on the first floor, 2 levels of underground parking.
OMG it is not pretty on the plumbing side. Used Acad for details and, yes, risers. Found the drawing to be the easy part.
Why Autodesk is so short sighted on the piping side, I don't know. I have used other 3D piping programs for industrial piping and found the whole process much less intimidating, easier to understand and not so limiting. One program even made it extremely easy to make a 3d movie of a walk thru of the building.
As a plumbing designer, I really need to know the structure obstacles of the building to create something close to what contractors will install. Most models I see have no structural information. Plus there is the conflict of at the end of the day, the Engineer signs drawings. Plumbing drawings, even at 1/4" scale are diagrammatic. Sure, with Revit one can create an installation model, but at 1/8" per foot scale, the drawings look like someone went crazy with a thick black Sharpie marker.
I find it not very intuitive to isolate architectural elements or hide the ones I don't need.
If I had a choice, which I don't, I would look for another program to do 3d piping.
I recently completed a project in REVIT (I did all HVAC & Plumbing) from the contractors side & have attached a finished drawing. Obviously I am just showing the Plumbing here & there is a lot more duct & pipe. I do not know if this helps but tell me what you think.
