Show only
Search instead for
While trying to learn the electrical part of Revit MEP, I created a circuit without adding wiring. Now, when I select the circuit, the icons to add wiring don't appear.
Have you done the electrical tutorials? Did you add an electrical circuit (using the "lightning bolt" symbol, not just a drawn on circuit). Is it connect to a panel?
