I want to show the Panel Schedule as "Two Columns-Circuits Down", however, I can't seem to make Revit MEP 2011 give me the choice to apply the template. It is listed when I select the Panel Configuration under Template Type:Branch Panel. Any guesses on what it is I am missing?
Solved by eric_grey. Go to Solution.
Hi Dennis,
When creating a panel schedule for a panel, Revit checks the Panel Configuration parameter in the panel family and matches it to templates that use the same configuration.
HTH,
Eric
