I built a new MEP Model. I have linked the MEP template, Archi model and Structural model. Then I start to build the Fan.
The question is that I can't cut the section on the floor plan.
The warning is as follows.
how can I do?
I am just wondering if there are good ways to immediately delete the cut section which is invisiable in the view.
It is pretty hard to find inappropreate sections after I get warnings and they already settled in somewhere other views....
The method No.6 which you mentioned will be only applied to the case I set invisible to the section on the V/G setting
as far as I tested.
I would appreciate if you give me further advices!!
Thank you in advance!!!
Yuki
