I have a paragraph of text (using the automatic numbering per new line) and I cannot figure out how to automatically indent non-numbered lines to a certain point; I have to hit tab at the beginning of each line, and this can be annoying if I have to make revisions to said text. Is there a way to automatically indent, or must I do this manually?
I am running Revit MEP 2012, and thanks in advance!
Have you tried the "Text Generator" tool in the Autodesk Extensions add-in from the subscription site? That allows you to import externally created text and provides a little more word processing power thatn the usual text editor. That may help.
I have downloaded and installed the REVIT 2013 extensions, but I haven't a clue as to how to use them. Can someone please direct me to a help link?
@Anonymous wrote:I have a paragraph of text (using the automatic numbering per new line) and I cannot figure out how to automatically indent non-numbered lines to a certain point; I have to hit tab at the beginning of each line, and this can be annoying if I have to make revisions to said text. Is there a way to automatically indent, or must I do this manually?
Any updates on this one 8yrs down the line?
In my example I need to hit TAB at the start of each line - not ideal in large bits of text, and not intuitive if text is edited.
I see. If you want unconventional numbering then use a noteblock schedule.
