Revit MEP Forum
symbol with text (attribute)
1 REPLY 1
2353 Views, 1 Reply
I am attempting to create an annotation symbol, that is a hexagon shape, with a 3 character long text attribute in the middle. In can, this would easily be done with a block and an attribute. Can I mimic this process in Revit?
Creating the hexagon, is no probelm. I have tried to load a "label" into my shape, but then I can not edit the text once I load my symbol into my model.
Im assuming its an easy thing to create/fix, it is just eluding me so far.
Thank you in advance for any help!
Jarrad27
1 REPLY 1
CoreyDaun
If you have already created your Label in a separate family and have loaded it into the host family, it's an easy couple of steps from that point.
When you created the Label, you also created a Parameter to control the value of the Label. Now, in the host family, create that same Parameter, ensuring that it is at least of the same Parameter Type (i.e. Text, Number, Length).
After that, place an instance of the Label family into the "Ref Level" View, if you have not already done so. Select it and, depending on whether the nested Parameter is an Instance or Type Parameter, you will see it listed under Properties (Instance) or Type Properties (Type). Click on the a small gray button to the right of that Parameter to bring up a list of valid Parameters to link this to. Select the Parameter that you just created.
This will establish a direct link between these Parameters, so whatever value you enter for the host family will carry through to the nested Label.
Don't hesitate to ask if you have any questions!
