Hi Folks,
I should know the answer to this but I'm hitting a wall today. In attached image pipework that is under structural/architectural model is showing as lines. I would like to make these lines invisible, can someone please advise?
Kind Regards,
E
Solved by s.borello. Go to Solution.
select the lines (pipes) you want to HIDE - right click go to Hide in view select ELEMENTS
only the selected Elements will be hidden in that view (view specific
if they are in a linked model you can turn off that category through the link
You can select those objects and right click, and hide elements. Or, you can go to VG and turn off the category if you don't need to see any pipe. If they are in a RVT link, ensure you turn off the category of the linked model under VG.
Thank you for your replies but maybe I did not explain myself properly. I created the view using a selection box. I want the pipes to appear but I do not want them to appear as lines under elements in the view either.
Under VG you can make pipe appear as "Fine" this should make the lines go away, if I understand you correctly you want to see the pipe but not as lines.
