Revit MEP Forum
PIPE ELEVATION
1 REPLY 1
gurvinder.virdi
751 Views, 1 Reply
PIPE ELEVATION
Hi
I am wanting to tag pipe elevation in the MEP pipe section to relative datum so I can lates give inverts to OS Datum and not relative to the floor levels. Could you please explain how this can be done?
Regards
1 REPLY 1
CoreyDaun
in reply to: gurvinder.virdi
In Plan View, this can only be done if the datum you wish to report the offset from is a Level. You can use a Spot Elevation Tag (which can only be applied if the Pipe's geometry is visible, i.e. Detail Level: Fine); you will need to use a Spot Elevation Tag with the Type Properties settings "Elevation Origin" equals "Relative", and the Instance Properties setting "Relative Base" equal "[your datum Level's name]". You will have to set the Instance Property "Relative Base" each time you place one of these Tags, or use the pull-down on the Options Bar to set it before placement.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
