Revit MEP Forum
Multiple tags for Equipment
11 REPLIES 11
Message 1 of 12
1758 Views, 11 Replies
Is it possible to have multiple tags for a single family group.  For example, I have a tag for grilles, but I don't want to use the same tag for my hoods.  (both air terminals) Currently I just edit the hood family and chage the type to mechanical equipment, but I was wondering if multiple tags were possible.
11 REPLIES 11
Message 2 of 12
dennis
Yes.  As an example, you will find a light fixture circuit tag and a light fixture type tag.
Message 3 of 12
in reply to: dennis
How do you create multiple tag types for a category?  I'm trying to the use tag by category button.
Message 4 of 12
Edit any existing tag, save as to a new file, and change the category.  Then add labels from the list of available fields for that category or shared parameters.
Message 5 of 12
bsammis
in reply to: ToanDN
In addition to what ToanDN said about editing tags, to select which tag the Tag By Category command defaults to, click on the bottom of the "tag" seciton on the ribbon to choose default tags for each category.  In the Tag All command you can choose which tag to apply to all elements of that category in the view.
Message 6 of 12
RobDraw
Switching the default tag is even easier after they are in the view. Using create similar sets the default to the selected type.
Rob
Message 7 of 12
in reply to: RobDraw
I guess there is a communication issue here.  I don't seem to understand how these answers answer my question.  Again, I'm labeling all kinds of mechanical equipment, some mechanical equipment has 1 tag type and other equipment has a totally different tag style that looks totally different, has different fields, a different shaped icon etc.  I want to be able to click on the tag and switch to a different family type using the drop down after it has been created using the tag by category button .
Message 8 of 12
As long as your tags are loaded you should be able to select any relevant tag from the drop down menu on the property panel when you select the tag you want to change.
Message 9 of 12
RobDraw
I thought the other posts were covering the question well and I was just giving some additional information about working with multiple tag types for the same category.
Rob
Message 10 of 12
bsammis
You can do exactly that in one of two ways: either create separate tag families for each configuration you want, or create on family with multiple types, each type's label and shape controlled by yes/no visibility parameters unique to that type.  If you're not comfortable with the family editor and creating/adding parameters use the first option.  Once you have the families created and loaded into your project, you can choose which tag is the default option and change any tag to another at any time by selecting it in the plan and using the Properties drop down to choose a different one.
Message 11 of 12
in reply to: bsammis
I don't think this works, maybe it did at one point but i don't see the option now.
Message 12 of 12
bsammis
You have to create the tags and load them into your project first.
