Revit MEP Forum
Duct Rise / Drop Annotation Size
4 REPLIES 4
GHASEM_ARIYANI
860 Views, 4 Replies
hi
What is the purpose of Duct Rise / Drop Annotation Size?
Please do on the image.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 REPLIES 4
L.Maas
in reply to: GHASEM_ARIYANI
It is the same as with the pipe settings. It determines the size of the symbols for rising and dropping pipes (or ducts). Note that it is a project wide setting
Underneath screenshot, two projects. One with Pipe Rise/Drop Annotation Size of 3 mm. In the second project increased to 10 mm.
Louis
Please mention Revit version, especially when uploading Revit files.
GHASEM_ARIYANI
in reply to: L.Maas
Thanks for your answer
But my problem is on Duct
This change does not display Duct
L.Maas
You are correct. I assumed it was the same for pipe as duct (do not much duct myself). Apparently duct does not have single line drop/rise symbols (anymore?).
Duct will show the rise symbol based on the size of the ducting. Then it appears indeed that the "Duct Rise/Drop Annotation Size" has no function (anymore). So historical leftover?
Louis
GHASEM_ARIYANI
in reply to: L.Maas
Thank YOU
