Revit MEP Forum
copy systems
5 REPLIES 5
rvetrano
327 Views, 5 Replies
copy systems
When I copy a duct system how can I get it listed in system browser. i can get the supply and return to assigned to a system but they show up unassigned.
5 REPLIES 5
CoreyDaun
in reply to: rvetrano
Can you elaborate a bit on the situation and what exactly you're trying to do or copy? What version of Revit are you using?
rvetrano
While doing exercise student asked if we could copy system.
CoreyDaun
I tested both Copy and Copy/Paste and the System was maintained. That was in Revit MEP 2012. What version are you running? I know I've seen that behavior before. Did your System Duct just disconnect from Mechanical Equipment?
rvetrano
Using Revit MEP 2011. No system does not mantain. I select and have to name system.
CoreyDaun
At the moment I don't have the means to test in 2011, but I do know that the Systems and behavior have improved drastically since then. I remember there being many more flaws and quirks back then.
