Hi!
Short: I would like to select multiple objects and copy a shared parameter from 1xCategory 1 to multiple catergory 2.
Deeper:
I have a system where a single flow damper controls the flow to multiple Air terminals. I would like to select one flow damper and multiple air terminals and copy a flow damper parameter to all of the air terminals. I've created a shared parameter (MC Object Variable 1) for the flow damper where I name the Actuator
The air terminals being controlled by this flow damper should have the same value copied to a shared parameter (BJE_Ställdon). I can imagine this can be done with Dynamo, but my knowledge in that area is limited.
Thanks!
Are you trying to get Revit to do this automatically or are you completing the fields manually?
I want to select a couple of air terminals and 1 flow damper, then run a dynamoscript or so to complete this task.
If you’re manually selecting the items, why not just copy paste the value from the damper to the terminals?
I don’t really understand why you want a script for this.
