Not sure if this is a wish list item or not, and I'd rather not reinvent the wheel on this.
Some of the duct fittings have surface areas calculated, some dont. I'd like to have all the fittings report an area so I can schedule total sheet-metal areas. Anyone here know of an easier way of doing this than going through each fitting family and figuring out how to calculate the areas?
Solved by Alaaeldin_Alsahli. Go to Solution.
I asked the same duct area question a while ago, no answers. No information on anywhere. I am still working on getting the duct area easily. What I do is define a shared parameter, and define a formula for that fitting area. A very easy task is turning into a tedious work. Schedule duct and fitting separately, export them, open them in a spread sheet, delete "m²", sum areas 😞
the only way is to create you shared parameters
here is a link for how to,
https://chronicle.autodesk.com/main/details/71a731f5-0982-4ade-b79e-f6f09ef6779e
See picture below. The calcs for a radius bend worked perfectly and scheduled perfectly.
Hi, I am working in the same task at my company, and I would like to know how did you do it, I did not find any PDF attachement.
Luis
i made the calculation sheet (from ashrae) . could have some mistakes, but not bad
my site :// ,,,,,,,,,,, ... linoavac.site.pro
Thanks for the email blast!
