Hi, i'm having some trouble with worksets, i've seen a lot of vedeos and guides (autodesk's ones too) about that and i got how it works, the only problem I have is about the central model..
If I save the central model in my pc (for examle in Desktop)then I can collaborate with 2 sessions of revit opened (with different nicknames) on the same model, but if I try to collaborate with another pc it doesn't work.
I know I have to save the central model to a network or something similar to share it live with those who works with me on that model, but I can't manage to do that..I tryied with Dropbox and Drive but it doesn't work..
Online I just can't find a clear explaination of what kind of service should I use to save it and collaborate on the same model from different computers, any help to make it clear?
thanks for your help.
Marco
Solved by Revit_Whisperer. Go to Solution.
All users need to be able to access the model in the same way in order for this to work. Each user must have a unique user name as well and read write access to the file location.
Revit is very particular about how you access the central file...you can only create a local file in Revit by browsing to the central file location in the same way that it was created otherwise create new local will be grayed out.
So for example I saved my central file to my network using the following path: \\Pc-sp01\g\_Support Testing\_S_Testing\Projects\2015\projectname.rvt
All users must get to this file the exact same way or they won't be able to create a local file through Revit.
Example:
Path to Central
Can't create local because the path is different (ie using a mapped drive)
