Can anybody please help. I am in the early days of learning Revit and have hit a snag while creating a parametric sink unit. It flexes all ways except for the depth when the sink leaves the void extrusion behind. Its ok on the width but I cannot see what I am doing wrong. I have tried adding ref planes and aligning / attaching, dimensioning and locking etc.
John
First of all i am informing you that you have uploaded a back up Revit file.
Secondly i am sending you that Revit family file with rectification. Please find the attached file.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thanks for taking the time to help me out. I am just trying to work out what you have done there.
It is early days for me but I have been teaching myself via an online course, its very good but learning is a lot easier when you have a little support!
Regards
John
If i have solved your problem then please accept it as solved. Send me Kudos also.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Just tally between two family. Then you will understand the exact process. I think first you have to understand what i have done in family by thorough checking. If i said to you what i have done then it would be make no sense for you for further creation a model like this. ok.
Please dont misundestand me. Try to grab it. If unable then i will tell you.
Thanks & regards,
Subhradeep Sen
Kolkata
India
