Is it possible to assign subcategories to Walls, so that I can control the
line weights??? I have a system panel furniture wall that I would live to
have as a different line weight then regular walls. I can edit the line
weight using the line weight command but it only effects the current view.
I guess it would almost make sense to do the wall as a family, if you can't
do subcategories.
