Wall types
1 REPLY 1
200 Views, 1 Reply
Wall types
hi
ive downloaded the student version of REVIT and it seems that mine lacks the different types of walls.
When i see tutorial videos, they have a lot more types of walls than mine.
How do i fix this problem? or are there upgrades that i need to download?
Thank you.
1 REPLY 1
Mostly you will need to 'develope' and build you own wall types to suit your individual needs.  Wall Types are Sytem Families, which means they are note 'exportable' to families as most other familes, and due to there probably as many wall types throughout as ther are projects and designer.  RAC comes with the basic building blocks within the stratup template, and as you develope and build your own project template(s), you can build and add the Wall types to them.
Mike
Forma Design Contest
