Just what I needed!
Thanks a lot,
Ak
"sdbrown" wrote in message
news:22543404.1090243419510.JavaMail.jive@jiveforum1.autodesk.com...
> Here is the way I approach this.
> 1. anywall that stacks and is the same wall type should be one wall going
thru all floors, this way it will move on all levels when you move it on
one. you can use the join geometry tool to clean up your sections.
> 2. place all the doors on one level, then select all doors and group them.
then copy/paste align that door group to all levels. now when you edit the
door group it will update each level.
> An alternative if you don't like the walls going 3 stories(and not being
true to construction) would be to group the walls and the doors, then copy
paste that group to each floor. There can be some issues with groups. But
if its just walls and doors and worksets aren't involved you should be fine.
