Transfer Drafting Views
4 REPLIES 4
2507 Views, 4 Replies
Is there a way to pull a drafting view from one project into a sheet on another project or do you need to recreate the Drafting Views and cut and paste?
Thanks for your help,
4 REPLIES 4
The File menu Save to Library Save View allows you to save Drafting view, Goups and Sheets to external Revit (RVT) files for loading into other projects. Check it out in HELP.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
MasterGraphics, Inc.
In the project browser, you can right click on the drafting view name and
select "Copy to clipboard". Then "Edit -> paste from clipboard" it into the
other project. It will then be in both projects.
Thomas
unfortunately nether of these options appear to be available in version 8.1
No, they are not. 90+°% of the questions being posed apply to the newest version of the software, not one that old. In your version, the only option is to cut and paste. PLEASE be morespecific on version numbers when posing questions.
Forma Design Contest
