I have many stacked wall assemblies in my project. When I create a structural floor plan (changing the discipline setting) several instances do not display.
This tells me that the instances do not have a parameter setting of bearing, foundation, or shear. But, how can I set this? I see no option within the stacked wall edit menu. and, the walls that make up the assembly have "instance" parameters for structural usage, but not type parameters.
so far, I am selecting the walls, changing the type to a basic wall type, setting the structural use, and they changing it back to a stacked wall type. Time consuming, but it works...sort of. The problem with this method is that it is deleting wall sweeps and other hosted objects.
Any pointers would be greatly appreciated.
thanks.
