OK... got it. Crystal clear now. Thanks.
Matt Dillon
Enceptia, Inc.
http://www.enceptia.com
"Greg Cashen" wrote in message
news:403e6f51$1_2@newsprd01...
> Because you can have a two cut fascia and the dimensions of the two cuts
> will change based on the depth of the fascia...for instance, if you want
to
> put a gutter on the fascia, you will need at least 4.5 inches of plumb
> fascia to have it attach flush with the bottom. But you could also go for
> 5.5 inches or whatever you like.There is an infinite combination of fascia
> to cut depth ratios and not everyone does them the same.
> "Matt Dillon" wrote in message
> news:403e65af$1_2@newsprd01...
> > OK, cool - that did it. Thanks.
> > Can you tell me WHY the fascia depth even matters? Just curious.
> > Matt Dillon
> > Enceptia, Inc.
> > news:403e351c$1_2@newsprd01...
> > > You need to change your option to 2 Cut Square and then give it a
large
> > > fascia depth. 2 Cut Plumb and 2 Cut Square are not the same.
> > > news:403e27ac$1_2@newsprd01...
> > > > I can't seem to get a roof to have square cut rafters in 6.0. The
roof
> > > > properties allow for 3 options:
> > > > Plumb cut - vertical roof edge
> > > > 2 cut square - horizontal roof edge - THAT looks wierd
> > > > 2 cut plumb - same thing as 2 cut square
> > > > Is this a defect, or is there some other way to have a square cut
> fascia
> > > > (other than applying a sweep to the edge of the roof)?
> > > > Matt Dillon
> > > > Enceptia, Inc.
