SNAPPING TO TOPOGRAPHY POINTS???
11 REPLIES 11
Message 1 of 12
5929 Views, 11 Replies
I want to create new revit topography and snap to points on another revit topography surface.(particularly points along the edges) Is this possible? John
11 REPLIES 11
Message 2 of 12
No. The typical procedure is start with a large topo surf and then using the split topo surf tool you can create the edge condition you are looking for.
I recommend allways having 2d lines drawn as a guide for spliting surfaces. So since you allready have one surf drawn, just draw a line where you want the common edge to be and make your new surf. then split that surf. along that line.
Message 3 of 12
Seychellian
Did you ever solve this?
Im struggling to believe that I can't position two topographies together and align them accurately with this $3000 software without doing some abstract export to dwg and re-import. My mind is literally blown.
Message 4 of 12
in reply to: Seychellian
Welcome to reality I guess...
Message 5 of 12
Seychellian
in reply to: ToanDN
I don't like this reality.
Message 6 of 12
WholeLLC
Hey guys,
Actually this is pretty easy to do.  Just to the view that you want to use the topography snaps from.  Then export this view as a DWG.  Then insert the DWG back into the view and that's it.  You will now be able to snap to the lines.  FYI, Marcello Sgambelluri has a video on YouTube going into more detail on this workflow.  Any questions let me know!
Message 7 of 12
in reply to: WholeLLC
Message 8 of 12
WholeLLC
in reply to: ToanDN
I guess I missed the asterisk.  Either way though it's an easy solution!
Message 9 of 12
syman2000
This is how I would do it.
https://youtu.be/fXfIuO_NmlM
Message 10 of 12
mgiurizzato
in reply to: syman2000
This is genius! Thank you so much @syman2000 !!!
Message 11 of 12
staedler1822000
thanks a lot for this idea!
Message 12 of 12
jcortelyou
I am going to be the person in the Revit forums that says it's your fault and that the software wasn't designed to do this and you have to do X Work around, you should know better, how dare you Criticize Revit 🙂
Forma Design Contest
