Hello all
I have an issue here.
A little background first:
-I have a pattern based curtain wall panel in a facade model that I link into my main model.
-The building has many sloped faces = sloped facade
-This pattern based curtain wall panel has a visibility parameter (instance parameter) that controls lines in the family to show an operable vent panel. In elevation and in plan. Some panels are operable some are not. Other than that they all look the same.
-I have set the swing lines on elevation to only show front and back never in plan.
-I have set the swing lines for the plan to only show up in plan never front and back
The issue is in both plans and sections:
-all the lines show up everywhere.
-in the facade file the cut plane of the section will cut the elevation swing lines so they only show up under the cut line.
-In the main model were all the sheets are the elevation swing lines show up completely not being affected by the cut plane of the plan view.
Has anyone come across this issue and found a solution?
I am currently using revit 2012. I cannot upgrade to any newer versions.
Thanks for any help!
