I have had this in the past too.
You do not draw a closed sketch line (like a box or triangle) you are just drawing the profile - so do not try and make an extrusion for the plywood, or rafters - instead just sketch the outter shape it is supposed to be, and in the properties pick what kind of roof Revit is to make - and it will take care of all of the pieces to it.
B
