So got a query someone might be able to answer for me, at present I have set up parameters that in each sheet we can manually type in the corresponding sheet that lines up with the current sheet if there are break ups.
My question is, is there a way to have this reference a list of all the sheets in the project and just select from like a drop down instead of typing it out ?? or is there actually a better way revit handles breaking up a level into multiple sheets if it is larger then one sheet.
Cheers in advance,
Mark
