Hello I am trying to save a local file to the Revit Sever. My Revit progress bar has been stuck on 100% for nearly 40 minutes now and I am showing a yellow triangle with black exclamation point on the revit server admin console. Any help would be appreciated
thanks
Jonathan
It could be a "lock" on a user file on the Central Server, caused by a crash from a local user.
It could also be a corrupt .db3 file as well.
Hello - thanks for the response. I've manually deleted the lock files. Are you referring to the model.db3 file?
I've tried this procedure 3 times now and still keep getting same results.
Anyone ever seen this error? My users get it when opening 2 or 3 central models using Revit Server.
I came across a few posts regarding the "...element became corrupt..." message.
I don't know if this will lead you anywhere, but below is the most recent discusision that I found.
