Revit content library missing
2 REPLIES 2
458 Views, 2 Replies
I know there are a lot of posts on this showing how to correct this mistake, but I can't seem to correct my problem after following them.
The Autodesk Revit Content Libraries  2015 is not in Programs and Features, as shown in attached image. Now when I clcik Autodesk Revit 2015 it doesn't give me the option of adding the conent, just the options to repair/reinstall or unistall.
Can I get any addvice on the problem.
Timmy
2 REPLIES 2
I think you should repair, or reinstall, so you get the option to choose those file on the screen. Then it can load those file back into your computer.
edwin.prakoso
 Try to run the installer again, use the setup.exe in installer media. You should be able to install Content Libraries.
Cheers,
Edwin Prakoso
Forma Design Contest
