I am running Windows 7 Professional 32 bit and I keep getting an error message saying "An error has occured while drawing the contents of this window. This window shall be closed." This happens very often, and randomly. I also had alot of trouble installing Revit Architecture 2012 yesterday from the disk, it kept freezing and I ended up downloading it from autodesk's website. I am wondering if anyone has any solutions to either of these problems?
Solved by kathryn.langan. Go to Solution.
Hi Kate,
I would suggest taking a look at the following Technical Solution on our Knowledge Base: An error has occurred while drawing the contents of this window.
Let us know if this helps!
I try the link that you put in your comment but it does not work for me. any other suggestions..?
Are you using a Wacom tablet? If so, you can try to disable the "Tablet PC Input Service" in Computer Management. This has help.
Katie, thank you so much, I am a brand new user, Revit would not even allow me to draw two walls without giving me this error message and shutting down. I unchecked that box and it works fine now.
Thanks again
Drew
Great Drew - I'm glad it helped!
I also want to thank you Katie for the solution. It worked like a champ and now abel to use Revit Architecture 2012. You are the greatest
Thank You,
Rich
