Hi! We are upgrading our PC's over the next couple of weeks. What are some "best practices" to remove the Revit software from our old PC's and install on the new ones?
Thanks!
Rob
Solved by BIMologist_. Go to Solution.
I just install the software on the new computers and register it. If you are not going to use the old PC's, I would format the hard drive and be done.
One other suggestion would be to create a Deployment on the server with the Autodesk software wanted. Then all you have to do is click on that install and let it do its own thing. Launch the software an select the Create Deployment button. It will walk you through the process.
BIMologist1
Thank You! I think this will do the trick. I appreciate your help with it. I will let you know how it works when we do our upgrade (sometime next month)
Thanks again,
Rob
