I'm using RVT 14 and I believe there is no way to create a double digit revision number for single digits (i.e. 1-9 to 01-09). Unfortunately in NYC, double digits are a requirement. Is there a way to create a double digit revision number that is still a "smart" number? I don't want to leave it up to the user to place a number every time there is a revision and thus creating more room for error. Also note that we do revisions per sheet and not by project; so, any workaround would have to follow that parameter.
Thanks!
You should assign revision numbers' parameters to "issued by" or "issued to" instead of revision numbers and you can do anything to revision numbers.
Thanks for the reply. Isn't this only applicable to 'per project' and removes the 'smart' aspect leaving room for error. The problem is that we do not issue every sheet per revision. Only revised sheets are resubmitted. This allows every sheet to follow a sequential order (01, 02, 03...) per revision rather than 01,03,05... per sheet.
I figured out a "workaround". I added two fields overlapping each other. The first is plain text with "00" and the second is the label 'Current Revision' with the sample text as 01 for reference. Both the text and label are set to opaque. The text is aligned left and the label aligned right. This allows for the current revision number to always be to the right of the '0' text. The label supercedes the text field so once you hit double digits in your revisions, i.e. 10, the label overlaps the text field and hides it due to the label being set to opaque. Now all revisions that are less than 10 will show a 0 in front with the revisions still being 'smart' and negates human error. This also allows for '00' to be set as the default which means no revisions as of yet because the text is "00". Because there are no revisions to the sheet, the current revision label is off by default.
I spent a couple of hours struggling with this. It is easy to add a "0" prefix to the numeric revision numbering but when we got to revision 10 Revit started to show the revisions as "010", "011", etc. and the document controllers started rejecting our drawings. The solution is just to use alphanumeric revision numbering - delete the "A,B,C,D,E,F,...." and insert "00,01, 02,03,04,.........09,10,11,12,....". I've gone all the way up to 30. If we ever get past that revision I can always add a few more.
i was struggling with this issue as well, i just found a supper easy approach to solve this issue:
in the "revisions" window (under Numbering Options) click on "Numeric..." in the newly opened window click inside "Prefix" chamber and Press Space on your keyboard! In this way you are adding one character to your revision numbers.
Hope this helped.
@Anonymous wrote:I figured out a "workaround". I added two fields overlapping each other. The first is plain text with "00" and the second is the label 'Current Revision' with the sample text as 01 for reference. Both the text and label are set to opaque. The text is aligned left and the label aligned right. This allows for the current revision number to always be to the right of the '0' text. The label supercedes the text field so once you hit double digits in your revisions, i.e. 10, the label overlaps the text field and hides it due to the label being set to opaque. Now all revisions that are less than 10 will show a 0 in front with the revisions still being 'smart' and negates human error. This also allows for '00' to be set as the default which means no revisions as of yet because the text is "00". Because there are no revisions to the sheet, the current revision label is off by default.
Could you describe in better detail how you were able to achieve the overlapping text and label to opaque and how the plain text "00" fills the revision schedule for numbers 1 thru 9?
-luc
Using Revit 2022
Go to View and select Revision
In the Numbering column, click and select Numeric from the list and click Customize Numbering.
Duplicate Numeric and rename to Number1to9 by clicking then Pencil icon.
In the Settings..
- Minimum number of digits = 1
- Starting Number = 1
- Prefix = 0
...then hit Okay
Select this Numbering method for revisions 1 to 9 only and use the default Numeric for 10 and above
Hope this helps
From the OP:
"I'm using RVT 14 and I believe there is no way to create a double digit revision number for single digits (i.e. 1-9 to 01-09)."
-luc
