I have one of the floors in our building doing something wacky.
The 5th floor reflected ceiling plan looks fine so I create detail plans for the suites at a different scale. this new suite blowup has what looks to be the same suite but everything is greyed out and when i switch from coarse detail to fine detail it doesn't do a thing.
The orignal full reflected ceiling plan looks fine. The line are black. The detail swithces back and forth...
I can;t figure out what the problem could be. I used the same process on other floor and everyting is OK.
The View Ranges are the same and everthing else in the properties seem the same too.
Anyone else come across this?
Mike
Solved by mhamson. Go to Solution.
Not specifically - what is the discipline set to?
LD
That s wasn't it...but it did make me look at the bootom of the properties dialgue box and notice that the Phase was set to "Phase 3". We don't even have phases in this project. Ooops! Wonder how that got changed.
Problem solved.
Thanks for the help.
MIke
Glad to be of assistance... kind of...
LD
