Quantities of layers of the wall,
In the screenshot below, I wanted to have the total volume and area for each layer of the wall. For example, the total volume of the concrete is 6.00+2.94=8.94.
How to further group the “material: name” such that the areas and volumes are summed up?
Thank you for the help,
Best
Jamal
Solved by jesser. Go to Solution.
@JamaL9722060 wrote:Quantities of layers of the wall,
Best
Jamal
Thank you Jesser for the answer.
Please, have a look on the screenshot below. What I wanted is to summarize the schedule table as shown in the Excel table.
Can I do this type of summery in the Revit without the need to go to Excel?
Jamal,
Take a look at the attachment. You should be able to achieve what you are looking for by manipulating the schedule properties.
Good luck. Let me know if you have more questions.
Jesse
Thank you Jesse for the very informative answer and the screenshots. This is very helpful.
Best
Jamal
Hi again Jesse,
Could you please elaborate more concerning the issues below:
Thank you
Best
Jamal
Jamal,
I can elaborate a little, but we are getting close to the end of my knowledge. So hopefully someone who know more will chime in if I speak out of turn.
Area:
Material Area:
Material Paint:
Material Volume:
Volume:
Now of course my units are different, but I've tried to show my calculations below.
I am not sure why the volume categories are not showing up in your schedule. But the Material Paint is displayed correctly. You could try creating your own calculated value in the Field tab. In the formula you can manually add parameters.
See the attachment as I was having trouble pasting into the body of this reply.
Jesse
Many thanks for the elaboration Jesse.
The link below contains my simple file in case you have time to see why the values of Area and Volumes are not included in the schedule.
http://www.mediafire.com/?lxl210v4xxz6hhd
Best
Jamal
