You are certain that you are printing with the setting for "Zoom 100%"?
Most people that have this issue are actaully using the "Fit to Page"
option, which causes the print driver to shink the drawing to fit on the
page within the margin limits of the printer. Since all titleblocks have a
line defining the edge of them that in theory is the edge of the paper, the
print driver will scale this smaller to fit this "border" line on the sheet
without cutting it off. Most large format printer cannot print "full bleed"
which means to print to the very edge of the paper.
wrote in message news:5891868@discussion.autodesk.com...
When I print in revit - at scale - 100% Zoom, I check it with an
architecture scale and its off. For example, 25' - 0" in the revit file
measured with a scale on paper is 23 ' 10". etc... Has anyone had these
issues before? Is it a revit issue, or a printer driver issue?
Adam
