While using Revit 2014, the pop up videos that show how to use a command freeze in my screen and they do not go away unless I close the program.
I have tried ticking and unticking the use hardware acc in the graphics option but there is no difference. Please see attachment of screen shot.
I don't know if this is a Revit problem or if it is the laptop where I am working from which is a brand new Dell with the specifications required to install Revit.
Thanks for your help!
have you installed all the latest updates from autodesk? have you update latest version driver of your graphics card. Try to update first and see what is the outcome. thanks and regards.
hi, sorry to say. you cant download the graphics card, what i meant download latest version of your grahics card "Driver" (it will depends what type of graphics you used in your laptop?) go to start > contro panel > device manager (check the type) please see attached.
or go to this site to update your Revit software
http://knowledge.autodesk.com/support/revit-products/downloads#?sort=score
hope it helps.
