We're about ready to pull the trigger on some new systems at our office and have a pretty good system spec'd out.
Quad Core Xeon E5630, 2.53GHz, 12M L3, 5.86GT/s, Turbo
12GB, 1333MHz ECC DDR3
1GB Quardro 2000
Windows 7 64-bit
The Quadro x000 line of cards is brand new and does not show up on AutoDesk's Revit Certified Graphics Hardware list....does anyone know if Autodesk plans to support/certify this card? My guess is yes, but I wanted to know if anyone has any insight into Autodesk's plans. Thanks!
Newer cards should be fine as long as they meet the requirements outlined in the technical solution below:
Thank you,
Seth,
I've put together some systems with the new Quadro 2000 and from what I have seen, it is a great card. No problems with Revit that I saw as I went through my benchmarking process. These are built on the same core as nVidia's high-end gaming GPU, so the high-fidelity oomph is there.
